Maximilian_Mar1's avatar
Maximilian_Mar1
Jul 19, 2017
Using v13 Default Cipher in v12
Hello,
im curious if I should use Default Ciphers from the newest BIG-IP version 13 for my F5, using 12.1.0 HF2. Cause the Default Ciphers in v13 are defined by new standards I assume.
Does this way of thinking make sense for you?
Greetings and thanks for your advice, Maximilian Martin
  • Normally we don't upgrade ciphers unless we upgrade bip ip version, because we think it is good idea align version and default ciphers.
