Mike_61707's avatar
Mike_61707
14 years ago
Using tmsh to manage data-groups
I'm trying to use tmsh to update an internal data-group on v11.1.0. I can create the data-group and add records to it, but when I try to create either a key or value that includes spaces I get an error.
In this example I create the data-group and add a key and value pair that don't include spaces. This works as desired.
[root@mike-f5:Active] config tmsh create ltm data-group internal new_dg type string
[root@mike-f5:Active] config tmsh modify ltm data-group internal new_dg records add {"string1" {data "value"}}
[root@mike-f5:Active] config tmsh list ltm data-group internal new_dg
ltm data-group internal new_dg {
records {
string1 {
data value
type string
Now if I try to add a record that has a space in the key name I get an error:
[root@mike-f5:Active] config tmsh modify ltm data-group internal new_dg records add {"string2 with space" {data "value"}}
Syntax Error: records: required brace is missing "{"
I also get an error if I try to add a record that has a space in the value:
[root@mike-f5:Active] config tmsh modify ltm data-group internal new_dg records add {"string3" {data "value with space"}}
Syntax Error: incomplete command
I tried a few different combinations of quotes and escape characters but can't seem to find anything that works...
  • I figured this out, turns out you just need to escape the quote with backslash. Here's an example:
    tmsh modify ltm data-group internal new_dg records add {\"string with space\" {data \"value with space\"}}
