John_Heyer_1508's avatar
John_Heyer_1508
Apr 20, 2017
Solved
Using String Match to Check if all Numbers
Basically I'm looking to test if a string is 10 digits and all numbers. Matching the 10 digits works, but not having any luck verifying if all numbers. This is the code I'm trying to use:
 set STRING "1234567890"
 if { [string length $STRING] == 10 && [string match {^[0-9]*} $STRING ] } {
   log "The string is 10 digits"
  • Try this:
    when ACCESS_ACL_ALLOWED {
             if { [string length $STRING] == 10 && [string is digit $STRING ] == 1 } {
                log local0. "The string is 10 digits"
                log local0. "The string is not 10 digits"
  • Try this:
    • John_Heyer_1508's avatar
      John_Heyer_1508
      Thanks! "is digit" is the shortcut I was looking for. I had been trying "string is integer", but in order for that to work I would have had to type it to int first, which seemed like an unnecessary step.
