selvam's avatar
selvam
Sep 17, 2019
Using REST API i need to add string and value inside iRule datagroup.
Greetings,
I am able to filter data which is inside the datagroup using $select=records, but i am unable to filter inside the records and post as well.
https://localhost/mgmt/tm/ltm/data-group/internal/~Common~DataGroup_Mohan_test?
output:
"kind": "tm:ltm:data-group:internal:internalstate",
"name": "DataGroup_Mohan_test",
"partition": "Common",
"fullPath": "/Common/DataGroup_Mohan_test",
"generation": 177197,
"selfLink": "https://localhost/mgmt/tm/ltm/data-group/internal/~Common~DataGroup_Mohan_test?ver=11.5.4",
"type": "string",
"records": [
"name": "ENSS_rockers",
"data": "GNOC.amat.com"
"name": "GNShome",
"data": "gnshome.com"
},... continue
Please help !!!
BTW i am using python.
