Using iRules to conserve public IP addresses
Hello all,
I've been tasked with coming up with a solution using one public IP address and laod balancing it to multiple pools using iRules and host-headers. Currently, we're doing a one to one NAT. I created a virtual server and used the iRule below, which is using Data Groups. I was able to successfully accomplish this for http but I cannot get https to work. If anyone can provide some input, I'd much appreciate it.
if { [class match [string tolower [HTTP::host]] equals TestRedirect] } {
set usepool [class match -value [string tolower [HTTP::host]] equals TestRedirect]
pool $usepool
Here is the Data Group for the http pools.
ltm data-group internal /Common/TestRedirect {
records {
TESTA.net {
data TESTA_80_pool
TESTB.org {
data TESTB_80_pool
TESTC.com {
data TESTC_80_pool
type string
I was assuming that they wanted it to be seamless rather than present a cert error but you are correct, if you didn't mind the cert error appearing any cert applied to a client SSL profile would work for this.
- Lee_Payne_53457
The only way this would work is if you had a SSL certificate containing SAN's for each domain you want to use for your iRule, without a proper SSL cert to decrypt the traffic what you want to do is impossible.
- nathe
Cirrocumulus
Would it be impossible? You'd need a client SSL profile so the f5 can decrypt the traffic so the irule can inspect the http traffic. Then if there is a cert mismatch wouldn't you just get the certificate warning in the browser and need to click on Continue? Not pretty of course so yes, you'd want a wildcard cert of some description.
- Lee_Payne_53457
- donmon_10187
Thanks for the information guys. I'll explore the options. Seamless is what we'd want but I'll need to build the solution first and go from there.
