epaalx
Cirrus
Jan 24, 2012Using bpsh to merge configuration
Hi F5'ers,
I've noticed that F5's solutions (eg. http://support.f5.com/kb/en-us/solutions/public/13000/100/sol13114.html) involving "bigpipe httpd include" involve bpsh.
My question - why preference for bpsh - why not using
- bigpipe httpd include '" httpd_config_commands '"
- bigpipe merge
commands?
R's, Alex
- hoolio
Hi Alex,
I think any of those methods would work. Have you tested either/both of them?
Aaron - epaalx
Cirrus
Hi Aaron, thanks for reply.
I've successfully used bigpipe command.
As for merge - as I understand it requires the to-be-merged SCF-like content has to be complete, that is, containing whole object definition - I wouldn't be able to modify parameter values (eg. only changing value of httpd's "include" parameter). Correct?
R's, Alex - nitass
Employee
I wouldn't be able to modify parameter values (eg. only changing value of httpd's "include" parameter). Correct?i think so. anyway, what i usually do is to print current object configuration, e.g. b httpd list > temp.txt, modify it and then merge it.
