abdulmalek's avatar
abdulmalek
4 years ago
User's session timeout and concurrent session (Layer 7) using F5 LTM
Hello,
I hope all is well :)
We want to control the user's session timeout and concurrent session (Layer 7) using F5 LTM; however, after researching the documentation, we couldn't find a way to do so except with APM. can you please advise on how to do so without APM?
Appreciate your corporation.
BRs,
Abdulmalek Aldosrri
  • Hi
    I guess user's session timeout value relate to timeout value
    and then concurrent session is using below irule
    when RULE_INIT {
      set static::maxquery 1
      set static::holdtime 600
    when CLIENT_ACCEPTED {
      set srcip [clientside {IP::local_addr}]
      if { [table lookup -subtable "blacklist" $srcip] != "" } {
        drop
        return
        log local0. "abc"
      set curtime [clock second]
      set key "count:$srcip:$curtime"
      set count [table incr $key]
      table lifetime $key 600
      log local0. $count
      if { $count > $static::maxquery } {
        table add -subtable "blacklist" $srcip "blocked" indef $static::holdtime
        log local0. "excute"
        table delete $key
        drop
        return
  • Much appreciated neeeewbie, will test it and let you know! By the way, we have created an irule that removes all browser cookies after a specific time interval to address the timeout issue. it's working fine with us :)
      set now [clock seconds]
      if { [HTTP::cookie exists lastrequesttimestamp] } {
        set lastrequesttimestamp [HTTP::cookie value lastrequesttimestamp]
        set lastrequesttimestamp $now
      set cookieNames [HTTP::cookie names]
    when HTTP_RESPONSE {
      set threshold [expr {20}]
      set lastRequestPlusThreshold [expr {$threshold + $lastrequesttimestamp}]
       if { $lastRequestPlusThreshold < $now } {
        foreach aCookie $cookieNames {
          HTTP::cookie insert name $aCookie value bb
          HTTP::cookie expires $aCookie 1
         HTTP::cookie insert name "lastrequesttimestamp" value $now path "/"
        HTTP::cookie attribute "lastrequesttimestamp" insert "SameSite" "None"
        HTTP::cookie secure "lastrequesttimestamp" enable
