URL monitoring problem
2 different web servers have to be monitored by LTM with version 10.2.0.
1 is 10.10.1.32 with monitoring URL http://10.10.1.32/Web/status.htm. It returns "Running" and I turn on debug with following messages.
2011-06-16 17:01:09.458329: ID 23 :(_send_active_service_ping): writing [ addr=::ffff:10.10.1.32:80 srcaddr=::ffff:10.10.1.7:54665 ] send=GET /Web/status.htm HTTP/1.1\x0d\x0aHost: 10.10.1.32\x0d\x0aConnection: Close\x0d\x0a\x0d\x0a
2011-06-16 17:01:09.458436: ID 23 :(_send_active_service_ping): sent ping [ addr=::ffff:10.10.1.32:80 srcaddr=::ffff:10.10.1.7:54665 ]
2011-06-16 17:01:09.458527: ID global:(_main_loop): about to select for 0.100000s
2011-06-16 17:01:09.458986: ID 23 :(_main_loop): rfd selected [ addr=::ffff:10.10.1.32:80 srcaddr=::ffff:10.10.1.7:54665 fd=9 pend=0 ]
2011-06-16 17:01:09.459065: ID 23 :(_recv_active_service_ping): reading [ addr=::ffff:10.10.1.32:80 srcaddr=::ffff:10.10.1.7:54665 ]
2011-06-16 17:01:09.459163: ID 23 :(_recv_active_service_ping): rcvd 304 bytes: -->HTTP/1.1 200 OK\x0d\x0aContent-Type: text/html\x0d\x0aLast-Modified: Tue, 14 Jun 2011 08:06:52 GMT\x0d\x0aAccept-Ranges: bytes\x0d\x0aETag: "036a946a2acc1:0"\x0d\x0aServer: Microsoft-IIS/7.5\x0d\x0aX-Powered-By: ASP.NET\x0d\x0aDate: Thu, 16 Jun 2011 09:06:15 GMT\x0d\x0aConnection: close\x0d\x0aContent-Length: 41\x0d\x0a\x0d\x0a\x0d\x0a\x0d\x0aRunning\x0d\x0a\x0d\x0a<-- [ addr=::ffff:10.10.1.32:80 srcaddr=::ffff:10.10.1.7:54665 ]
2011-06-16 17:01:09.459257: ID 23 :(_recv_active_service_ping): Response matched regex [ addr=::ffff:10.10.1.32:80 srcaddr=::ffff:10.10.1.7:54665 ] send=GET /Web/status.htm HTTP/1.1\x0d\x0aHost: 10.10.1.32\x0d\x0aConnection: Close\x0d\x0a\x0d\x0a
recv=Running
disable=
monitor configuration:
monitor monitor_10.10.1.32_1 {
defaults from http
recv "Running"
send "GET /Web/status.htm HTTP/1.1\r\nHost: 10.10.1.32\r\nConnection: Cl
ose\r\n\r\n"
Actually this monitor works find.
However I have another similar monitor which does not work properly. 10.10.1.12 with monitoring URL http://10.10.1.12/health/health.aspx. It returns "OK" and my monitor is configured to match "OK". When the server returns "NOTOK" on purpose, the monitor still deem the response as matched, with following debug message.
2011-06-16 17:01:07.455238: ID 11 :(_send_active_service_ping): writing [ addr=::ffff:10.10.1.12:80 srcaddr=::ffff:10.10.1.7:34974 ] send=GET /health/health.aspx HTTP/1.1\x0d\x0aHost: 10.10.1.12\x0d\x0aConnection: Close\x0d\x0a\x0d\x0a
2011-06-16 17:01:07.455344: ID 11 :(_send_active_service_ping): sent ping [ addr=::ffff:10.10.1.12:80 srcaddr=::ffff:10.10.1.7:34974 ]
2011-06-16 17:01:07.455465: ID global:(_main_loop): about to select for 0.100000s
2011-06-16 17:01:07.457013: ID 11 :(_main_loop): rfd selected [ addr=::ffff:10.10.1.12:80 srcaddr=::ffff:10.10.1.7:34974 fd=9 pend=0 ]
2011-06-16 17:01:07.457131: ID 11 :(_recv_active_service_ping): reading [ addr=::ffff:10.10.1.12:80 srcaddr=::ffff:10.10.1.7:34974 ]
2011-06-16 17:01:07.457223: ID 11 :(_recv_active_service_ping): rcvd 277 bytes: -->HTTP/1.1 200 OK\x0d\x0aCache-Control: private\x0d\x0aContent-Type: text/html; charset=utf-8\x0d\x0aServer: Microsoft-IIS/7.5\x0d\x0aX-AspNet-Version: 2.0.50727\x0d\x0aX-Powered-By: ASP.NET\x0d\x0aDate: Thu, 16 Jun 2011 09:06:14 GMT\x0d\x0aConnection: close\x0d\x0aContent-Length: 39\x0d\x0a\x0d\x0a\x0d\x0a\x0d\x0aNOTOK\x0d\x0a\x0d\x0a<-- [ addr=::ffff:10.10.1.12:80 srcaddr=::ffff:10.10.1.7:34974 ]
2011-06-16 17:01:07.457316: ID 11 :(_recv_active_service_ping): Response matched regex [ addr=::ffff:10.10.1.12:80 srcaddr=::ffff:10.10.1.7:34974 ] send=GET /health/health.aspx HTTP/1.1\x0d\x0aHost: 10.10.1.12\x0d\x0aConnection: Close\x0d\x0a\x0d\x0a
recv=OK
disable=
monitor monitor_10.10.1.12_1 {
defaults from http
recv "OK"
send "GET /health/health.aspx HTTP/1.1\r\nHost: 10.10.1.12\r\nConnection: Clo
se\r\n\r\n"
Could someone shield some light on this? Many thanks!
Daniel
- hoolio
Hi Daniel,
The problem is that the receive string of OK is being matched even when the server returns NOTOK. Can you try this regex in the receive field (removing all of the spaces)?
( ? < ! N O T ) O K
It should match OK only if it's not preceded by NOT.
$ cat test.html
this line only contains OK so it should match
this line contains NOTOK so it should not match
$ grep -P '( ? < ! N O T ) O K' test.html
Aaron - Daniel_55334
Altostratus
Thanks for your prompt reply. However I got this error message during configuration (I removed all spaces)
01070753:3: Monitor monitor_10.51.1.12_1 recv parameter contains an invalid regular expression (Invalid preceding regular expression).
I am sorry that I don't know much about regular expression. - Daniel_55334
Altostratus
Hi hoolio,
From your reply I think what I need is a regex of matching only the "OK" string. I will try to figure it out. Many thanks! - hoolio
Actually, it looks like you can't use a negative lookbehind in a monitor receive string. There are a few other options:
use a receive string of \r\nOK
change the app to return a unique string like DOWN instead of NOTOK
Altostratus
Hi hoolio,
I tried "^OK$" which I assume is the exact match of the string "OK". But then the member is marked down. Is the regex wrong? - nitass
Employee
would u mind trying this?
(.*)^ok
sol5917: Using regular expressions in a health monitor receive string
http://support.f5.com/kb/en-us/solu...l5917.html - Daniel_55334
Altostratus
Hi nitass,
Your suggestion works for all string that starts with "OK", e.g. OKOK
How can I make it only to match "OK"? - hoolio
Were you able to try a receive string of:
\r\nOK
If that doesn't work, can you try:
\x0d\x0aOK
sol4186: Entering escape sequences in an ECV health monitor's send and receive strings
http://support.f5.com/kb/en-us/solutions/public/4000/100/sol4186.html
Altostratus
Hi Aaron,
Both of them do not work. The member is marked as down. However as I am at home now so I can only test it with VE which is 10.1.0. Not sure if that matters. - nitass
Employee
i think i know what is wrong. ok is also in http header i.e. http status code
curl -i http://10.10.70.110/monitor1.html
HTTP/1.1 200 OK
Date: Fri, 17 Jun 2011 19:29:21 GMT
Server: Apache/2.0.59 (rPath)
Last-Modified: Fri, 17 Jun 2011 19:21:47 GMT
ETag: "6696-4-4bf4a8c0"
Content-Length: 4
Vary: Accept-Encoding
Content-Type: text/html; charset=UTF-8
ABC
curl -i http://10.10.70.110/monitor2.html
HTTP/1.1 200 OK
Date: Fri, 17 Jun 2011 19:29:32 GMT
Last-Modified: Fri, 17 Jun 2011 19:22:41 GMT
ETag: "6693-7-4f2ca240"
Content-Length: 7
NOTABC
curl -i http://10.10.70.110/monitor3.html
HTTP/1.1 200 OK
Date: Fri, 17 Jun 2011 19:29:47 GMT
Last-Modified: Fri, 17 Jun 2011 19:22:51 GMT
ETag: "65bb-7-4fc538c0"
Content-Length: 7
ABCABC
[root@tulip:Active] config b monitor myhttp list
monitor myhttp {
defaults from http
interval 2
timeout 7
recv "(.*)^abc\n"
send "GET /monitor1.html HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n"
[root@tulip:Active] config b pool pooh list
pool pooh {
monitor all myhttp
members 10.10.70.110:http {}
POOL pooh LB METHOD round robin MIN/CUR ACTIVE MEMBERS 0/1
| (cur, max, limit, tot) = (0, 0, 0, 0)
| (pkts,bits) in = (0, 0), out = (0, 0)
+-> POOL MEMBER pooh/10.10.70.110:http active,up
| session enabled priority 0 ratio 1
| requests (total) = 0
monitor myhttp {
defaults from http
interval 2
timeout 7
recv "(.*)^abc\n"
send "GET /monitor2.html HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n"
POOL pooh LB METHOD round robin MIN/CUR ACTIVE MEMBERS 0/0
+-> POOL MEMBER pooh/10.10.70.110:http inactive,down
monitor myhttp {
defaults from http
interval 2
timeout 7
recv "(.*)^abc\n"
send "GET /monitor3.html HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n"
