Ralph_David_201's avatar
Ralph_David_201
Dec 24, 2017
URI to lower case LTM irule issue
Hi Team,
I have a challenge to redirect all uri into lower case. I am able to redirect the URL to lower case but if i type in e.g myweb.net/fR/PAges/DEfauLT.aspx etc it does not redirect to lower case e.g myweb.net/fr/pages/default.aspx. I am trying my best but not sure where actually issue lies. Your help is very much appreciated.
 STREAM::disable
HTTP::path [string tolower [HTTP::path]]
 if { [string tolower [HTTP::path]] equals "/" } {
            if { [HTTP::header "Accept-Language"] starts_with "fr" } {
                HTTP::respond 301 -nocase "Location" "https://www.myweb.net/fr/pages/default.aspx" Strict-Transport-Security "max-age=300
elseif { [HTTP::header "Accept-Language"] starts_with "en" } {
HTTP::respond 301 -nocase "Location" "; Strict-Transport-Security "max-age=300" }
} elseif { [string tolower [HTTP::path]] equals "/autodiscover/autodiscover.xml" } {
    HTTP::respond 301 "Location" "https://autodiscover.myweb.net/autodiscover/autodiscover.xml"
HTTP::redirect "http://[HTTP::host][string tolower [HTTP::path]][HTTP::query]"
} elseif { [string tolower [HTTP::host]] contains "blog.myweb.net" }{
HTTP::respond 301 noserver "Location" "https://www.myweb.net/en/tech/pages/default.aspx"
} elseif { [string tolower [HTTP::host]] contains "techpage.myweb.net" }{
HTTP::respond 301 noserver "Location" "https://www.myweb.net/en/tech/Pages/techpage.aspx"
when HTTP_RESPONSE {
 HTTP::header remove SPRequestGuid
    set cookies [HTTP::cookie names]
    foreach aCookie $cookies {
    HTTP::cookie secure $aCookie enable
if { [HTTP::header exists Location] } {
    HTTP::header remove Server
    HTTP::header replace Location [string map {"http://" "https://"} [string tolower [HTTP::header Location]]]
if { [HTTP::header Content-Type] contains "text" } {
   STREAM::expression { @http://s5.mywebnet.net@https://s5.mywebnet.net@ }
    STREAM::enable
  • I am able to redirect the URL to lower case but if i type in e.g myweb.net/fR/PAges/DEfauLT.aspx etc it does not redirect to lower case e.g myweb.net/fr/pages/default.aspx.
    where do you want the redirection to be generated? is it server or bigi-ip?
    if it is big-ip, i think myweb.net/fR/PAges/DEfauLT.aspx does not match condition in HTTP_REQUEST event because the outer-if is to check whether request path is equal to root (/).
    • Ralph_David_201's avatar
      Ralph_David_201
      Thanks nitass for your response. Redirection should be on F5 side for client requests with Upper case URI to Lower case URI.
      Ralph_David_201
  • Redirection should be on F5 side for client requests with Upper case URI to Lower case URI.
    e.g.
    // config
    [root@ve13a:Active:In Sync] config  tmsh list ltm virtual bar
    ltm virtual bar {
        destination 172.28.24.10:80
        ip-protocol tcp
        mask 255.255.255.255
        pool foo
        profiles {
            http { }
            tcp { }
        rules {
            qux
        source 0.0.0.0/0
        source-address-translation {
            type automap
        translate-address enabled
        translate-port enabled
        vs-index 3
    [root@ve13a:Active:In Sync] config  tmsh list ltm rule qux
    ltm rule qux {
      if { [HTTP::uri] ne [string tolower [HTTP::uri]] } {
        HTTP::respond 301 noserver Location http://[HTTP::host][string tolower [HTTP::uri]]
    // test
    [root@ve13a:Active:In Sync] config  curl -I http://172.28.24.10/fR/PAges/DEfauLT.aspx
    HTTP/1.0 301 Moved Permanently
    Connection: Keep-Alive
    Content-Length: 0
    [root@ve13a:Active:In Sync] config  curl -I http://172.28.24.10/fr/pages/default.aspx
    HTTP/1.1 404 Not Found
    Date: Mon, 25 Dec 2017 08:53:27 GMT
    Server: Apache/2.2.3 (CentOS)
    Last-Modified: Fri, 15 Apr 2016 03:55:49 GMT
    ETag: "418e44-6a-fc825b40"
    Accept-Ranges: bytes
    Content-Length: 106
    Content-Type: text/html; charset=UTF-8
      Ralph_David_201
      Awesome nitass.From curl output i see it shows to lowercase but i see in browser URI remains in uppercase instead of redirected to lowercase.
    • nitass's avatar
      nitass
      you may have to perform further troubleshooting such as tcpdump/ssldump, http analyzer tool or irule logging to see where the problem is.
    • stan_piron's avatar
      stan_piron
      I always recommend path-relative absolute URLs when destination page is on the same service as the current page:
          HTTP::respond 301 noserver Location [string tolower [HTTP::uri]]
      the problem when working with absolute URLs is when a reverse proxy is configured in front of the server with another hostname or scheme, rewriting is required.
    e.g.
    // config
    ltm virtual bar {
        ip-protocol tcp
        pool foo
        profiles {
            http { }
            tcp { }
        rules {
            qux
        source 0.0.0.0/0
            type automap
        vs-index 3
    ltm rule qux {
    // test
    Content-Length: 0
    Content-Length: 106
      Ralph_David_201
    • nitass_89166's avatar
      nitass_89166
      Icon for Noctilucent rankNoctilucent
      stan_piron
