drosenfield_199's avatar
drosenfield_199
Jan 29, 2012
uri rewrite for IIS conversion
Hi I am currently in the process of moving sites away from Microsoft ARR to F5
there are quite a few url rewrites involved and the syntax is causing me an issue
current rule on IIS looks like this
rule name="Rewrite to details"
match url="^Details/([0-9]+)/([a-z]+)" /
conditions logicalGrouping="MatchAll" trackAllCaptures="false" /
action type="Rewrite" url="PropertyDetails.aspx?HID={R:1}&L={R:2}" appendQueryString="false" /
/rule
the question is how do I write this in irule speak? just the match and the rewrite the rest doesn't matter
any help would be great
  • i am not familiar with iis rewrite rule. can you give example url?
  • hi
    I don't have an example to hand but the this works is the property number is given in value 1 and passed to R:1 and the language code in value 2 R:2
    so an example would look something like http://host/details/123/en and the output would be http://host/propertydetails.aspx?HID=123&L=en
    hope this helps
    thanks
  • please feel free to revise.
    [root@ve1023:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.79:80
       ip protocol 6
       rules myrule
       profiles {
          http {}
          tcp {}
    [root@ve1023:Active] config  b pool foo list
    pool foo {
       members 200.200.200.101:80 {}
    [root@ve1023:Active] config  b rule myrule list
    rule myrule {
            if {[scan [string tolower [HTTP::uri]] {/details/%d/%s} u1 u2] == 2} {
                    HTTP::uri "/propertydetails.aspx?HID=${u1}&L=${u2}"
    [root@ve1023:Active] config  ssldump -Aed -nni 0.0 port 80
    New TCP connection 1: 172.28.19.253(34582) <-> 172.28.19.79(80)
    1327896840.4802 (0.0029)  C>S
    GET /details/123/en HTTP/1.1
    User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8r zlib/1.2.3 libidn/0.6.5
    Host: 172.28.19.79
    Accept: */*
    New TCP connection 2: 200.200.200.10(34582) <-> 200.200.200.101(80)
    1327896840.4813 (0.0009)  C>S
    GET /propertydetails.aspx?HID=123&L=en HTTP/1.1
    Host: 172.28.19.79
    Accept: */*
  • Hello Nitass,
    I have an issue where the following IIS URL Rewrite is causing 502. The application is Cold Fusion (no jokes please) using TomCat and IIS. If I disable the rule F5 works and hits test html pages on each web server. When the IIS URL Rewrite is enabled it fails.
    Is there a way to tweak the rule on IIS to make it work, or will the rules need to reside in an iRule?
    Any help is much appreciated.
    Error:
    502 - Web server received an invalid response while acting as a gateway or proxy server.
    There is a problem with the page you are looking for, and it cannot be displayed. When the Web server (while acting as a gateway or proxy) contacted the upstream content server, it received an invalid response from the content server.
    IIS URL Rewrite Rules/Code:
