Guruprasad_3773's avatar
Guruprasad_3773
Dec 13, 2018
Uploading SSL Crt and Key
Using F5 12.1.2
Trying to upload ssl crt and key using REST
Tried: curl -sk -u "credentials" -H "Content-Type: application/json" -X POST -d '{"command":"install", "name": "mykey", "fromLocalFile": "mykey.key"}'
Error: {"code":400,"message":"Unable to copy (/var/service/restjavad/temp/mykey.key) into tempfile (/var/system/tmp/tmsh/huwouz/mykey.key), No such file or directory","errorStack":[],"apiError":26214401}
Tried: curl -sk -u "credentials" -H "Content-Type:application/json" -d '{"partition":"Common","name":"mykey","sourcePath":";}' -X POST
Error: {"code":400,"message":"Failed! exit_code (37).\n","errorStack":[],"apiError":26214401}
Same errors for crt
The files have permission: 644
Any suggestions?
  • How about using my iCR Python module which does the upload and in fact the whole thing for you if you want?
    iCR Python Module for iControl REST
    Use the create_cert method and in fact there is a create_ssl_profile method as well. Let me know if you want some help.
