Upgrade from 10.1.0 to 10.2.1 - Snmp issues
I just upgraded our pair of 6400 from 10.1.0 to 10.2.1.
Upgrade wasn't an issue and it went fine, however afterwards I notice that most of the oids in F5-BIGIP-LOCAL-MIB is not working anymore.
While other things works as before.
Doing a full snmpwalk on one of the devices returns lots of data. But the F5-BIGIP-LOCAL-MIB returns nothing regarding vs statistics and our beloved 400/500 counter is gone also.
.1.3.6.1.4.1.3375.2.2.10.2.3.1.1 (Virtual Server Name) - No oid.
and so on..
Anyone knows anything about this or is experiencing same issue? Can find any info on it.
- JRahm
Admin
I have 10.2.1 running (albeit with hotfix1 applied) and I am able to peruse that table just fine:[root@golgotha:Active] mibs snmpwalk -v 2c -c public localhost F5-BIGIP-LOCAL-MIB::ltmVirtualServers.2.3.1.1 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName."tmshtest1" = STRING: tmshtest1 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName."tmshtest2" = STRING: tmshtest2 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName."tmshtest3" = STRING: tmshtest3 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName."tmshtest4" = STRING: tmshtest4 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName."tmshtest5" = STRING: tmshtest5 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName."tmshtest6" = STRING: tmshtest6 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName."tmshtest7" = STRING: tmshtest7 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName."tmshtest8" = STRING: tmshtest8 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName."tmshtest9" = STRING: tmshtest9 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName."tmshtest10" = STRING: tmshtest10 - pelle_71294
Sorry for being unclear regarding upgrade, applied hotfix 1 as well.
Most annoying. For some reason I don't get it working.snmpwalk -v2c -c public ..com F5-BIGIP-LOCAL-MIB::ltmVirtualServers.2.3.1.1 F5-BIGIP-LOCAL-MIB::ltmVirtualServStatName = No Such Object available on this agent at this OID
Will have to dig into this even more. - JRahm
Admin
Are you walking it locally on the BIG-IP or remotely? If remote and and you don't have the F5 mibs installed this won't work, you'd need to use the actual oid string. Walk it from localhost on the BIG-IP and see if you get the same response. Otherwise I'd get a case open with support so they can assist your efforts. - Mike_Kahler_488Historic F5 AccountHave you tried restarting snmpd?
bigstart restart snmpd - pelle_71294
Both internally and externally wasn't working.
No clue why I didn't do this from the beginning. Just restarted snmpd now and guess what? It's working. No clue to why it wasn't working after upgrade. snmpd was running and I could get a lot of other snmp data from the devices. But both devices now works after restarting snmpd.
Thanks for the pointers and help. Much appreciated.
