AT_6064
15 years agoUpdated iRule not applied to existing connections?
When I update an iRule it looks like any existing connections will continue to use the old version. Can anyone shed some light on this behavior?
- AT_6064
Clarification: in an earlier iteration of the iRule I logged a specific message to the log file. I have since changed this, but it looks like the old logging directive persists. Curiously, the other parts of the iRule are not persisting (which is good!). - hoolio
Hi Arie,
Theoretically, existing connections shouldn't be affected by a change to the iRule--they should continue to use the old version of the iRule. Spark commented on this in a post here:
iRule not applied immediately
http://devcentral.f5.com/Forums/tabid/1082223/asg/50/showtab/groupforums/aff/5/aft/1168308/afv/topic/Default.aspx
But I and others have seen some odd behavior when updating iRules on actively used virtual servers as described in the post. If you're able to reproduce the issue, you could open a case with F5 Support and ask them to help you investigate the issue.
Aaron
