DarioGB_339840's avatar
DarioGB_339840
May 28, 2018
Unknown flow from my F5
Hello folks!
I have noticed an unknown traffic in my lab enviroment from my F5 Self IP to one of my backend servers (internal VLAN).
  • SRC IP: 10.130.40.3 (F5 self-IP)
  • SRC PORT: random
  • DST IP: 10.130.40.192 (my zabbix server)
  • DST PORT: 443 (https)
 list net self | grep self
net self 10.130.40.5 {
net self 10.130.41.5 {
net self 10.130.40.3 {
net self 10.130.41.3 {
net self 1.1.1.1 {
I was trying to figure out why this traffic is generated (every 2 seconds) but i didn't find the root of this flow
Anyone could help me?
1.- I have checked all monitors involved, but nothing related to HTTPS.
 list ltm pool monitor
ltm pool JuniperSSL {
    monitor gateway_icmp
ltm pool Krennic_IMAP {
    monitor tcp
ltm pool Krennic_POP {
    monitor tcp
ltm pool Krennic_SMTP {
    monitor tcp
ltm pool Kylo_Ren {
    monitor tcp
ltm pool WebServer {
    monitor http
ltm pool syslog_pool {
    monitor none
ltm pool zabbix {
ltm pool zabbix_https {
2.- I have checked established conns but there is no info about this flow
 show sys connection
Really display all connections? (y/n) y
Sys::Connections
10.130.40.3:34687  10.130.40.192:8  10.130.40.3:34687  10.130.40.192:8  icmp  3  (tmm: 3)  none
10.130.40.3:34688  10.130.40.2:8  10.130.40.3:34688  10.130.40.2:8  icmp  4  (tmm: 0)  none
1.1.1.2:50726      1.1.1.1:1026   1.1.1.2:50726      1.1.1.1:1026   udp   0  (tmm: 0)  none
10.130.40.3:34684  10.130.40.2:8  10.130.40.3:34684  10.130.40.2:8  icmp  14  (tmm: 0)  none
10.130.40.3:34683  10.130.40.192:8  10.130.40.3:34683  10.130.40.192:8  icmp  13  (tmm: 3)  none
1.1.1.1:52137      1.1.1.2:1026     1.1.1.1:52137      1.1.1.2:1026     udp   0   (tmm: 3)  none
10.130.40.3:34685  10.130.40.192:8  10.130.40.3:34685  10.130.40.192:8  icmp  8  (tmm: 1)  none
10.130.40.3:34686  10.130.40.2:8  10.130.40.3:34686  10.130.40.2:8  icmp  9  (tmm: 2)  none
Total records returned: 8
3-. I have sniff traffic using ":nnnp" noise amplifier but no VIP info is related (so traffic is exclusively generated in my F5)
4-. I have used "losf" and "netstat" commands but there is no info related about TMM traffic (so they are unuseful).
I would like to know which process or config may be responsible of this traffic. Any help?
Thanks in advance.
KR, Dario
  • Hi Dario,
    First of, Just to be sure can you remove the monitor in the pool or all pool using the following node
    DST IP: 10.130.40.192 (my zabbix server) DST PORT: 443 (https)
    if the flow continue, it's not due to the monitor...
    Regards,
