EuropeanITCrow1's avatar
Jul 23, 2015
Universal persistence in iRule and mirror persistence
Hello everybody,
I have a problem concerning the universal persistence in version 11.5.2. I’m using an iRule like this:
when HTTP_RESPONSE {
  if { [HTTP::cookie exists "JSESSIONID"] } {
    persist add uie [HTTP::cookie "JSESSIONID"]
      persist uie [HTTP::cookie "JSESSIONID"]
The iRule itself works without any problems and I can see the persistence entries. The iRule is used on two virtual servers, one on port 80 and one on port 443 where I use a clientssl profile as well.
My goal is to get the entries mirrored onto the standby device, hence I created a persistence profile of type “universal”. In this profile I configured the corresponding iRule, timeout and – of course - mirror persistence.
When I check the persistence entries on the standby system I can see the mirrored entries only from the virtual server which listens on port 80 but not of the one listening on port 443.
Has anyone an idea why I can’t see the entries for port 443?
Thank you very much for your contributions!
  • You cannot currently mirror Secure Socket Layer (SSL) connections that are terminated by the BIG-IP system. If you enable connection mirroring for a virtual server that references a clientssl or serverssl profile, active connections being processed by the virtual server will be closed by the BIG-IP system when failover occurs. The BIG-IP system will send a TCP RST to the client when failover occurs, because the newly active BIG-IP system does not have the SSL connection in its connection table.
  • Hi Samir,
    many thanks for your reply. You're right, but I'm not talking about the connection mirroring but about the persistence mirroring. From what I know there shouldn't be a technical limitation to achieve this!
    Regards Otto
  • Thank you so much. I believe you have enable persistence mirror in VIP. Please go through this link. Thanks
