Two LTM in HA - Certs not being synced
We have 2 LTM's in a HA configuration and we just discovered doing a sync from the primary LTM to the backup, does not copy over the Certs and Keys. Is there an automated way to copy the certs/keys from the primary LTM to the backup? I don't see any options on the sync screen to include certs/keys.
Thank you
- afedden_1985
Cirrus
What version of code are you running? The Certs/keys used in the ssl:client profiles should sync across the HA pair.
- shifterracer_16
sorry, forgot to mention that. Version is 10.2.4 (build 577.0).
- afedden_1985
Cirrus
They should be syncing even in version 10. we use version 11. Have you searched the logs? possible searches? (tmos) show cm sync-status
or is there anything in the logs using bash zcat /var/log/ltm.gz | grep sync or zcat /var/log/ltm.gz | grep certificate
not sure if this is related but it mentiosn ssl files, sol14348:ConfigSync may fail when using the management IP address
- shifterracer_16
Going through the logs now afedden, wasn't sure that was part of the sync process or not.
