martin_58353's avatar
Oct 11, 2017
transfer values between sessions
Hello, I need transfer value between different client requests (sessions?). First I used cookie (e.g. cookie name "cookie-a"), but value of this cookie should be not visible on client site. I have other cookie (e.g. "cookie-b") based on it I can pair bot connections.
In first connection I need store value (before stored in cookie-a) on big-ip. In second connection I need read this value.
I can use session or table, but based on documentation it's not clear for me. https://devcentral.f5.com/articles/the101-irules-101-variables https://devcentral.f5.com/wiki/iRules.session.ashx https://devcentral.f5.com/wiki/iRules.table.ashx
what is better choose - session or table (I'm not familiar with both of them). where are more details about for session?
I have two apps (/server1.txt and /server2.txt) between this I need transfer value. In my lab I have three clients (different browsers on the same pc - FF, IE, EDGE). when I try to use 'session' (see code below) it is working but I'm not sure if this is correct code.
exists any better solution of this?
here is my code:
    switch [HTTP::uri] {
      "/server1.txt" {
         random value for client session (based on cookie 'cookiename')
        set uid [clock seconds]
        session add sticky cookiename $uid 30
        if { [HTTP::cookie exists cookiename] } {
          session add simple [HTTP::cookie value cookiename] $uid 30
      "/server2.txt" {
         read of value in another client connection (http request)
         it is working but I'm not sure if it's best solution
          set value [session lookup simple [HTTP::cookie value cookiename]]
        } else { set value "undefined" }
        HTTP::respond 200 content "this is uid='$value'" "content-type" "text/plain" "Connection" "close"
        event HTTP_REQUEST disable
martin
  • https://devcentral.f5.com/wiki/irules.table.ashx
    "The table command (like the session command) is a way to access the session table. The table command is a superset of the session command, with improved syntax for general purpose use. Please see the table command article series for detailed information on its use."
    I had an idea that table command was deprecated, but I can confirm that. Anyway, they do the same work.
    iRule looks ok, and using session table is the correct option. Just a small change, you dont need the event command.
    https://devcentral.f5.com/wiki/irules.http__respond.ashx
    "The BIG-IP will send the response as soon as the current iRule event completes, so you cannot alter the response in other HTTP iRule events."
