Traffic behavior after 1st failed monitor attempt
Hi guys,
I have a monitor configured for 60sec interval and a timeout of 181 sec.
I am using SIP, so I think that's a bit too much. What would happen with new connections after first failed monitor ? Will it still try to use that node? or we have to wait 181 seconds until we no longer direct NEW requests to that pool member?
Thanks!
- nathe
Cirrocumulus
Until 181 seconds has elapsed the pool member will still be marked as UP, or rather if it's UP it won't mark it down. Once the BIG-IP has not received a monitor response for 181 seconds then the pool member is marked down and, in effect, the BIG-IP won't load balance and new connections to it.
Hope this helps,
N
