Samit_jadhav's avatar
Samit_jadhav
Apr 07, 2020
Topology issue in gtm
Gtm has pool set with below pool members
Server A from London A area
Server B from London B area
Server A from Singapore A area
Server B from Singapore B area
Server A from US A area
Server B from US. B area
LB method set to topology
Client from London when tries to access gtm url , it toggles between 2 London servers.
The expectation from the london client is that everytime only (server A from London) should be resolved by gtm.
Could someone please advise... Thanks!
  • So in this scenario is London A Primary and B secondary?
    Also have you defined a topology regions?
  • Yes it should be in that way. Topology has given low value to London A server therby making it A primary whereas the other with higher ​value is secondary.
    Also the topology regions are been defined. Thanks!​
