Tomcat and Web Sockets
Hi All,
Looking for some advice/guidance here as this is my fist setup with a F5 load balancer. We have an application that runs in a tomcat container, that application also contains an embedded mqtt(activemq). The client when connecting initiates a http/80 request to log into the application to tomcat, then the client tries to subscribe to the mqtt topic and maintain that connection to the server. The challenge I have is that the http request to the tomcat server must be sticky as well as the web socket request. The request has to hit both the port 8080 and the mqtt port on the same server to maintain its state. Version 13.0.0.
client -> F5:80 -> pool:tomcat:8080 -> "get ws://F5:80/mqtt" -> pool:tomcat:1884
- edjv_352934
For some reason the code block was seen as spam here is the configuration:
TMSH-VERSION: 13.0.0 ltm node /Common/10.0.112.193 { address 10.0.112.193 monitor /Common/tomcat_8080 } ltm node /Common/10.0.112.199 { address 10.0.112.199 monitor /Common/tomcat_8080 } ltm node /Common/10.0.112.239 { address 10.0.112.239 monitor /Common/tomcat_8080 } ltm pool /Common/tomcat-1884 { description tomcat-embeded-mqtt load-balancing-mode least-connections-member members { /Common/10.0.112.193:1884 { address 10.0.112.193 } /Common/10.0.112.199:1884 { address 10.0.112.199 } /Common/10.0.112.239:1884 { address 10.0.112.239 } } monitor /Common/tcp } ltm pool /Common/tomcat-8080 { description "tomcat9 servers" members { /Common/10.0.112.193:8080 { address 10.0.112.193 } /Common/10.0.112.199:8080 { address 10.0.112.199 } /Common/10.0.112.239:8080 { address 10.0.112.239 } } monitor /Common/tomcat_8080 service-down-action reselect } ltm rule /Common/tomcat-mqtt { when HTTP_REQUEST { if { ([HTTP::uri] starts_with "/mqtt") } { HTTP::cookie insert name "APPCLIENT" value [HTTP::cookie value "APPCLIENT" ] use pool tomcat-1884 } } } ltm virtual /Common/acme-e7 { destination /Common/10.0.112.243:80 fallback-persistence /Common/dest_addr fallback-persistence-type destination-address ip-protocol tcp mask 255.255.255.255 persist { /Common/ACME { default yes } } pool /Common/tomcat-8080 profiles { /Common/apm-forwarding-client-tcp { } /Common/http { } } rules { /Common/tomcat-mqtt } source 0.0.0.0/0 source-address-translation { type automap } translate-address enabled translate-port enabled } ltm virtual-address /Common/10.0.112.243 { address 10.0.112.243 arp enabled mask 255.255.255.255 traffic-group /Common/traffic-group-local-only } ltm monitor http /Common/tomcat_8080 { adaptive disabled defaults-from /Common/http description "tomcat port 8080" destination *:8080 interval 5 ip-dscp 0 recv none recv-disable none send "GET /e7/\r\n" time-until-up 0 timeout 16 } ltm persistence cookie /Common/ACME { app-service none defaults-from /Common/cookie } ltm persistence cookie /Common/ACME-Cookie { always-send enabled app-service none cookie-encryption disabled cookie-name APPCLIENT defaults-from /Common/cookie expiration 0 httponly enabled method insert override-connection-limit disabled secure enabled } ltm persistence cookie /Common/cookie { always-send enabled app-service none cookie-encryption disabled cookie-name APPCLIENT expiration 0 hash-length 0 hash-offset 0 httponly enabled method insert mirror disabled override-connection-limit disabled secure enabled } ltm profile websocket /Common/acme-websockets { app-service none defaults-from /Common/websocket masking selective } With other persistence methods you could use the 'Match Across Services' function. However, this function is not available for cookie persistence. I found the article below, that explains how to achieve about the same with the use of the universal persistence method.
See: https://www.fir3net.com/Loadbalancers/F5-BIG-IP/cookiepersist-https.html
For more information about the 'Match Across' functions see:
https://support.f5.com/csp/article/K5837
