Grant
Oct 02, 2011tmsh deleting persistence records
Currently have a few VIP's running on a LB and need to delete a persistent record as they have static assigned cookies that can’t be change manually.
This is how I currently do it:
bigpipe persist node 10.50.56.73:80 mode cookie key 03 delete
with tmsh it would be something like:
tmsh delete /ltm persistence persist-records virtual MELPROD01-vs mode cookie node-addr 10.50.56.73 node-port 80 key 03
But you get the following error:
Data Input Error: If you specify a parameter for persist key, you must specify a mode and no other parameter than mode.
and would only accept:
tmsh delete /ltm persistence persist-records mode cookie key 03
I cannot delete with just cookie and value 03 as this value is used in multiple pools/VIPs
Has anyone been able to do this or write a script to perform this? (any hints would be good. )
