tmm traffic did not loadbalance properly during spike connection
Hi
anybody has experience change MHDAG algorithm on viprion ?
based on this article
https://my.f5.com/manage/s/article/K14306048
i have checked tmm-traffick not loadbalance during spike traffic and tmm cpu2 spike up to 100% and others cpu less than 40%, what is impact if cpu2 tmm continous 100% ?
Usually any cpu hike to 100%, it will make traffic disruption and uneven load balancing in pool. In the attached link it's mentioned what is MHDAG, cause and resolution.
https://cdn.f5.com/product/bugtracker/ID700827.html
if you use heavy irules, try to reduce the log action or convert them to local traffic policy.
avr analytics should be also disabled for live traffic.if youre backedn traffic is http/s, enable oneconnect in http profile to reduce number of tcp connections to backedn servers.
