uni
Altocumulus
Jul 17, 2006Tip: Using iRule to comment your configuration
As iRules are the only place you can put comments in a BigIP configuration, it occured to me that they could be used to document your config, like a change log:
rule change-log {
17/7/2006 - stephen - Add virtuals for Bordermanager
10/7/2006 - stephen - Initial build
}or any other noteworthy item:
rule comments {
Note that blah-vip has a public IP, but access to it is not allowed through the firewall
until QA testing is complete.
}It's a pity you can't make them show at the top of your config, but it is better than nothing.
If anyone thinks this is a bad idea, let me know, otherwise I'm going to start doing this.
- JRahm
Admin
If rules aren't loaded into memory unless they are called by a profile or a virtual server, then I can't see any performance reason why this would be a problem. - hoolio
Hi Stephen,
You could always submit a request for enhancement via support if you think it would be helpful to be able to add/view comments (in the GUI?) to the objects in the configuration.
Aaron
