Dennis_02_13882's avatar
Dennis_02_13882
Dec 11, 2013
Sync issues with Active/Standby pair
I have tried to sync an Active/Syandby Big-IP LTM VE pair config and get an error stating that a VS is not on the Standby F5. This is after I've added some VS definitions to the Active F5. IS this normal? I would think that a sync would update the Standby F5's config to match the Active F5. Otherwise what good is it? Or am I mis-sunderstanding what a sync operation is in relation to the Big-IP LTM? Thanks
  • Hi Dennis,
    Which version are you using ? In 11.4, you can enable auto-sync. Previous releases need manual sync.
    First of all, is your cluster UP ? Do you see "In Sync" on the top left corner ? Before making any modification on active unit. You can check "Overwrite" box to test if this solve your issue.
    I built a video, in french (sorry), explaining how to make an LTM cluster : http://youtu.be/HweeOFgBDNc
    Let me know.
    Matt
