ASM attack signatures not syncing between active and standby F5
Hello F5ers,
I have a pair of f5s in active/standby setup running ASM (WAF) module. I have ASM synchronization setup with sync-failover device group on both f5s. Everything else works fine but I noticed ASM signatures under system > software management > live update page no longer shows any signatures downloaded or installed my standby f5 anymore. when i try to select an option for "Installation of automatically downloaded updates" such as Real time or scheduled then click Save, I get a "failed to save configuration" error.
This db variable value is same on both f5s
tmsh list /sys db liveupdate.allowautoinstallonsecondary value
sys db liveupdate.allowautoinstallonsecondary {
value "false"
Standby f5:
cat /var/log/tomcat/liveupdate.log | egrep 'isMaster|isAsmMaster|isDatasyncMaster'
2026-06-17 16:20:51 INFO SyncHandler:343 - Set isAsmMaster = true
2026-06-17 16:20:51 INFO SyncHandler:351 - Set isMaster = true
2026-06-17 16:20:51 INFO SyncHandler:347 - Set isDatasyncMaster = false
2026-06-17 17:18:46 INFO SyncHandler:351 - Set isMaster = true
2026-06-17 17:18:46 INFO SyncHandler:343 - Set isAsmMaster = true
2026-06-17 17:18:46 INFO SyncHandler:347 - Set isDatasyncMaster = false
2026-06-23 15:10:23 INFO SyncHandler:343 - Set isAsmMaster = true
2026-06-23 15:10:23 INFO SyncHandler:351 - Set isMaster = true
2026-06-23 15:26:03 INFO SyncHandler:351 - Set isMaster = true
2026-06-23 15:26:03 INFO SyncHandler:343 - Set isAsmMaster = true
2026-06-23 15:26:03 INFO SyncHandler:347 - Set isDatasyncMaster = false
2026-06-23 15:41:11 INFO SyncHandler:351 - Set isMaster = false
2026-06-23 15:41:11 INFO SyncHandler:343 - Set isAsmMaster = false
2026-06-23 15:41:11 INFO SyncHandler:347 - Set isDatasyncMaster = false
Active F5:
2026-06-17 16:39:29 INFO SyncHandler:347 - Set isDatasyncMaster = true
2026-06-23 15:36:50 INFO SyncHandler:343 - Set isAsmMaster = true
2026-06-23 15:36:50 INFO SyncHandler:351 - Set isMaster = true
Did anyone came across this issue in their environment?
version: 17.1.3
platform: VM
Appreciate any help! thanks
Hi P_K,
I’ve encountered a few issues related to the ASU sync problem.
Newly added and updated article:
ASM Automatic Signature Update (ASU) Fails to Sync to Standby Unit After Upgrade
https://my.f5.com/manage/s/article/K000161737
Bugs identified in a case opened to the support:
Live Update configuration sync failure in HA setup
https://cdn.f5.com/product/bugtracker/ID2219081.html
"Live Update" API is unresponsive after upgrade and recover only after tomcat restart
https://cdn.f5.com/product/bugtracker/ID2152445.html
tmsh restart sys service tomcatOften helps
