Derick_Vaughan1
Jul 31, 2008super_http_monitor and ntlm issue
Hello,
I am currently having an issue implementing a super_http_monitor that uses NTLM authentication to run service checks for some of our internal web applications that require authentication. Everything looks to be in place and working except I am getting bad password responses back from the IIS 6.0 server. I've tried making the password as simple as possible but still no luck. The account is an AD domain account.
If I switch the authentication type to basic in both the monitor and on the server, everything works fine. So I know the password is entered in correctly.
I have attached the trace file output from the debug.
Anyone ever run into this before?
Any help is appreciated.
- Deb_Allen_18Historic F5 AccountIt would be very helpful to know more about the monitor itself. Can you plz post the output of 'b monitor list'
thx
/deb - Derick_Vaughan1
Hi deb,
Here is the output:
[root@f5dev-mgmt:Active] / b monitor I_monitor-test list
monitor I_monitor-test {
defaults from external
AUTHTYPE "ntlm"
DEBUG "1"
HOST_HEADER "servername.dns.domain.net"
HTTP_VERSION "1.1"
MATCH_REGEX "F5"
PASSWORD "xxxxxx"
run "super_http_monitor"
URI_PATH "/f5monitor/f5monitor.htm"
USERNAME "domain\user"
