stmp tls/ssl monitor using curl, etc.
hello, I am trying to create an external smtp monitor that uses curl or perl but it looks like the libraries aren't installed. Is this correct? is there a way around this? I am testing against google's smtp servers and it works fine using curl on my windows or unix box but not the LTM. Is there a way to make this work on the LTM?
Output:
Errors I get on 11.2.1
[root@ltm1:Active:Standalone] config curl smtp://smtp.gmail.com -v
* Protocol smtp not supported or disabled in libcurl
curl: (1) Protocol smtp not supported or disabled in libcurl
[root@ltm1:Active:Standalone] config curl smtps://smtp.gmail.com:465 -v
* Protocol smtps not supported or disabled in libcurl
curl: (1) Protocol smtps not supported or disabled in libcurl
- Kevin_Stewart
Employee
This is correct. The cURL libraries do not include support for SMTP. Is there something more specific that you need from an external monitor that the built-in SMTP monitor cannot provide? - John_Ogle_45372
What do you mean? The default SMTP monitor does not show an optoin for a SECURE connection (TLS/SSL) or the ability to add username/password credentails. In my working curl examples, I cannot securely and supply a username/password combination. This is what I need to do with the LTM but if the needed libraries aren't load, then what are my options.
Thank you,
- nitass
Employee
curl will be updated to support pop3s, imap4s and smtps in 11.4.1 but it is not released yet.
ID391900 - curl needs updating to enable POP3S, IMAP4S and SMTPS monitors
also, there is rfe to add smtps monitor.
ID381184 - [RFE] Add SMTPS monitoring capability - John_Ogle_45372
I have 11.4 on my other box. I will test asap and respond back. Thank youl - nitass
Employee
I have 11.4 on my other box.i understand you need 11.4.1.
