Nathaneil0227_2
Sep 25, 2016Static Routing
Hi DC Experts/All,
Is it possible to add static route using VLAN as Resource type? Though I tried it on my VM and it is working but I can't try it to physical since I don't have.
Thanks.
-Nat
don't quite understand what you want but in general there shouldn't be much difference between virtual and physical. so if it works on the VM it will work on the physical.
