Telise_Mays_208
May 11, 2017Static Maintenance Page
I am trying to create a https VIP on the ltm that will always return a Static Maintenance Page using iFile. I don't want the VIP to have pool members. I just want the VIP's sole purpose to be responding the https request with the splash page that I have defined. The html page is created and accessible on the LTM. However, I am getting the following ssl error. Any ideas?
- SSL read: error:00000000:lib(0):func(0):reason(0), errno 104
- jaikumar_f5
Noctilucent
Can you do a SSL Dump ?
Sounds like you're missing a clientssl profile or forgot to enable automap. See below a working example from my lab environment.
Virtual Server:
ltm virtual vs_html_static_page { destination 10.23.98.13:https ip-protocol tcp mask 255.255.255.255 profiles { clientssl-insecure-compatible { context clientside } http { } tcp { } } rules { A_IRULE_STATIC_HTML_PAGE } source 0.0.0.0/0 source-address-translation { type automap } translate-address enabled translate-port enabled vs-index 219 }irule:
ltm rule A_IRULE_STATIC_HTML_PAGE { when HTTP_REQUEST { set html [ifile get "/Common/static_html_page"] HTTP::respond 200 content $html unset html } }
