Draven_186334's avatar
Draven_186334
Aug 29, 2018
SSLVPN using the F5 Edge Client
hello,
Is there any guides or iapps to setup a SSL VPN on APM using the F5 Edge client for windows 10? I can find one that includes webtop. Just need to get a straight SSLVPN on the F5 edge client.
Regards Daniel Watts
  • Hello Youssef, do you have the procedure on how to create a VPN on f5 to be used with the edge client on Windows, am not able to find anything like that. The remote client who uses the edge need to have access to all network services (shared files, applications, etc..) Thanks,
  • Hello Youssef, I was able to configure it on the F5 and working fine from the internal network, while from the external its not. I aleady have another configuration on the F5 for RDP, the virtual server configured for RDP is a different one but bith the VPN and the RDP are using the same interface connecting the F5 to the internal network, the RDP is using a public IP different from the VPN, RDP is accessible while the VPN is not, the firewall is rejecting the traffic destined to the VPN because of the following " bounce traffic detected"
