msp_64517
Nov 23, 2010SSL Termination - Broken Connection Safari and IE
I've searched through various topics but can't find a previous discussion/solution on this exact issue and was wondering if anyone has seen this before...Safari can’t open the page “https://www.domain_name/”. The error is: “unknown error” (kCFErrorDomainWinSock:10054)
I have an HTTPS VS that is using a new cert (signed/verified by Equifax). The https site loads perfectly in Chrome and Firefox but fails to load in both IE and Safari.
BigIP Sries/Version: 6400/9.0.1 <--- (I know, I am not allowed to upgrade, please don't laugh)
Browser Errors (on Windows 7):
- IE (version 8.0.7600.16385): 'Internet Explorer cannot display the webpage'
- Safari (5.03):
I have many http (not https) sites running on this system without any problems. My one HTTPS VS setup is very basic and I'm not using iRules:
1. I imported/uploaded the signed SSL cert and key
2. Configured a Client SSL Profile:
- Certificate and Key: set to the cert and key I uploaded
- Ciphers: !SSLv2:ALL:!ADH:!EXPORT40:!EXP:!LOW:@SPEED
- Unclean shutdown: disabled
3. Configured an HTTPS VS which is setup in the following way:
- ServerPort: 443
- OneConnect Profile: None
- Protocol: tcp
- Client Protocol Profile: tcp
- Address Translation: enabled
- Port Translation: enabled
- SNAT Pool: none (site won't work if set to automap)
- ServerSSL Profile: none (site won't work if set to 'serverssl')
- ClientSSL Profile: domain_name
If I change the certificate/key for this HTTPS VS to a signed cert/key for a different domain, then I at least get the 'domain name mismatch' warning in Safari, but IE still displays "cannont display the webpage".
The first question in this existing topic describes a similar symptom: http://devcentral-sea.f5.com/Forums/tabid/1082223/asg/50/showtab/groupforums/aff/5/aft/1172095/afv/topic/Default.aspx
Also, the real servers are running Apache 2.2 on Centos 5 (SSL support in Apache is not installed/configured on the real servers).
If anyone has come across this before and can share any insight, it would be much appreciated.
- nitass
Employee
would u mind posting b profile domain_name list all output here?
btw, have u ever run tcpdump/ssldump and have a look the packet? - msp_64517
Here is the output of b profile:
PROFILE domain_name CLIENT SSL parent: clientssl
| Virtual servers: https_209.61.x.x
| key: domain_name.key certificate: domain_name.crt
| conn (cur, max) = (0, 12)
| (in, out) = encrypt (1.909M, 19.53M) decrypt (0, 20.25M)
| record (in, out, bad) = (984, 5, 0)
When running tcpdump with -X (for both the "internal" and "external" interfaces on the BigIP) I am able to successfully grep the domain name and see that the requests are coming through properly for Firefox and Chrome using HTTPS. However, with IE and Safari, zero traffic is visible when performing HTTPS requests.
This implies that the SSL negotiation between the BigIP and these 2 browsers is failing and completely halting any further communication. I just can't determine what IE and Safari require and what I could possibly configure on the BigIP to allow successful SSL negotiation.
Thanks - msp_64517
THIS IS RESOLVED.
A colleague of mine was actually able to determine the cause of the issue.
It looks like the 'Client Certificate' section of the SSL client profile needed to be set to "Auto"
It's strange that this option not being enabled worked fine for Firefox and Chrome but not Safari and IE.
