Adolfo's avatar
Adolfo
5 years ago
SSL issue
Hello there,
We have a F5 LTM and a virtual server configured to a server in port 443, the topology is:
Computer --> F5 LTM --> switch --> server
When we try to connect to the server through https we saw the message "Connection reset" in the browser, but if we try to connect without passing the F5 the connection is successful. We don't have configured any SSL client profile or server.
This is the configuration on F5:
#Virtual Server
#________________________________________________________________________________
ltm virtual /Common/Server1 {
   destination /Common/10.1.5.X:443
   ip-protocol tcp
   mask 255.255.255.255
   pool /Common/Server1
   profiles {
       /Common/tcp { }
   source 0.0.0.0/0
   translate-address enabled
   translate-port enabled
#Pools
ltm pool /Common/Server1 {
   members {
       /Common/10.1.7.X:443 {
           address 10.1.7.X
   monitor /Common/https_443
#Profiles
# -Default Profile-
ltm profile tcp tcp {
   ack-on-push enabled
   close-wait-timeout 5
   congestion-control high-speed
   deferred-accept disabled
   delayed-acks enabled
   ecn disabled
   fin-wait-timeout 5
   idle-timeout 300
   keep-alive-interval 1800
   limited-transmit enabled
   max-retrans 8
   nagle disabled
   proxy-buffer-high 49152
   proxy-buffer-low 32768
   proxy-mss disabled
   proxy-options disabled
   receive-window-size 65535
   reset-on-timeout enabled
   selective-acks enabled
   send-buffer-size 65535
   slow-start enabled
   syn-max-retrans 3
   time-wait-recycle enabled
   time-wait-timeout 2000
   timestamps enabled
As you can see, we don't have any SSL client or server profile and we tried changing "translate-port" to disabled and "Source Address Translation" to auto map but none of these work.
Also we made a tcpdump and we can see the TCP Reset from 10.1.7.X (tcpdump.png) and some curl (curl.png), openssl (openssl.png and openssl2.png) and a telnet (telnet.png).
Hope you can help us to find out what's going on.
Thank you.
  • Your virtual server is very simple with no profiles that should interfere.
    Telnet isn't a good test for SSL connections other than stating that the port is open, use openssl or another utility to test the connection.
    You have to have some sort of SNAT translation enabled because your virtual server and pool member exist on different networks. Automap should be fine assuming you have a valid self-ip configured.
    The F5 is not manipulating the SSL handshake and especially not the http traffic considering it can't decrypt any of it due to SSL passthrough being configured here.
    Given the very simple configuration of the virtual server this would seem to be more likely an issue with the server or device between F5 and server.
    You can take a capture with F5 'noise' to see the reset cause:
    tcpdump -s0 -ni 0.0:nnnp host 10.1.7.x and host source_ip
