SSL errors when connecting to activate.f5.com
curl -kvv https://activate.f5.com
* About to connect() to activate.f5.com port 443 (#0)
* Trying 104.219.111.132...
* Connected to activate.f5.com (104.219.111.132) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* NSS error -5961 (PR_CONNECT_RESET_ERROR)
* TCP connection reset by peer
* Closing connection 0
curl: (35) TCP connection reset by peer
any ideas why we are seeing this error ?
I don't see any issue. Can you please telnet and see any blockage on network.
- bcrogerz
Cirrus
telnet activate.f5.com 443
Connected to activate.f5.com.
Escape character is '^]'.
Connection closed by foreign host.
ping to fqdn works , telnet to fqdn on port 443 works.
trying from an centos server
- bcrogerz
Cirrus
it turned out to be an SSL inspection policy was blocking the connection !
