SSL connection error, client certificate validation issue - RSASSA-PSS signature algorithm support?
2-way SSL VIP with client certificate "required", we are getting SSL connection errors. The LTM log contains:
SSL Handshake failed for TCP from 10.20.15.156:57757 to 172.20.104.11:443
The CA chain and leaf certs are all issued by Windows certificate svcs. I believe the problem is the use of the RSASSA-PSS signature algorithm in the certs. When I upload the CA chain and a client cert to the F5 and manually do an "openssl verify -purpose sslclient -verbose -CAfile ./ca.cer ./client.cer", I get error messages as follow:
[root@lb:Active:Changes Pending] ~ openssl verify -purpose sslclient -verbose -CAfile ./ca.cer ./client.cer
client.cer: /DC=local/DC=ad/OU=People/CN=Bucci, David/[email protected]
error 7 at 0 depth lookup:certificate signature failure
10346:error:0D0C50A1:asn1 encoding routines:ASN1_item_verify:unknown message digest algorithm:a_verify.c:152:
And my client cert does in fact have signature algorithm set to RSASSA-PSS. In order to prove to myself it's the RSASSA-PSS signature algorithm, I used a different CA chain/child cert, where the intermediate CA cert uses that signature algorithm, but the child cert uses vanilla sha1rsa, and in that case, the error statement changes to "error 7 at 1 depth" ... which I believe means the child cert was fine, but then when it traversed up 1 level to the intermediate CA cert, the problem occurred.
When I upload the exact same ca.cer and client.cer to a Red Hat box and run the same command, the certificate verifies fine -- as do the other child/CA chain, where the child has sha1rsa, but the intermediate CA has the RSASSA-PSS. That RHEL box is running openssl version 1.0.1e-fips 11 Feb 2013, while the F5 is at 11.4.1, with openssl version 0.9.8y 5 Feb 2013.
Does that seem like a cogent analysis? Are there any other steps it would make sense to take to further verify the root issue?
And, if the analysis is correct, is there any way to get the F5 to accept RSASSA-PSS as a signature algorithm?
thx!
- Kevin_Stewart
Employee
Just spitballing here, but a quick review of the openssl release notes indicates that PSS signing support is introduced in 1.0.1. The first version of BIG-IP to support this openssl version is 11.5.
I was hoping to come back and confirm that 11.5 handles RSASSA-PSS, Kevin, but unfortunately I didn't have a chance - before we upgraded to 11.5.1, we had to rebuild our CA chain (and reissue certs across the board) using sha256, because of other devices (Cisco ISEs, etc.) that clearly documented that they wouldn't handle RSASSA-PSS. If anyone reading this knows for sure that RSASSA-PSS is supported at 11.5 or later, pls confirm so!
- i wouldn't mind checking but i seem unable to generate such a certificate with openssl or xca, if you can provide me one or explain how to create it i can have a look.
- Sorry, boneyard, appreciate it, but we tore down our CA that used RSASSA-PSS ... apparently, a Windows CA burns in the algorithm to be used and you can't change it from the default request by request (which seems weird to me, but that's what I'm being told).
- candc
Cirrus
Still definitely an issue for me on 12.0.0
- bulk_194077
I have seen problems with it on 11.5.1 HF 7 - Jason_AdamsRet. Employee
I just ran into this, and have confirmed that support for RSASSA-PSS Signed Certificates are now supported starting in v12.1.0.
This was introduced through Internal Request For Enhancement (RFE) ID 511818.
