ssl clollectio or oneconnect please Help
The problem is, when a client opens a session to F5 and then connects to the SHPK Server, its session remains alive. Thus, a second client cannot connect to the SHPK Server since it only accepts one connection at a time. The SHPK Server accepts only one session simultaneously. Therefore it drops further session requests regardless of their IP Address and Port Number. The Clients are actually servers with IP addresses 10.10.40.30, 10.10.40.31 and 10.10.40.32 as demonstrated above. The Virtual IP connection to the SHPK server must be in the form a single SSL connection. Therefore all the clients’ sessions must be in the form of a unified TCP session on the Virtual IP. Note that we suppose the SHPK server is a part of the IP Pool : 10.10.40.100 The format message is ISO8385 The connection between F5 and Server is 2 way SSL The F5 configure as SSL server The connection between client an d F5 is clear
