Oliver_Schmidt's avatar
Oliver_Schmidt
Aug 04, 2006
SSL client cert rule only works with 9.1, not 9.2
attached Rule from Rick Masters works fine with LTM 9.1.2 but doesn't work with 9.2.3.
Any ideas?
Tuesday, December 07, 2004
Requiring an SSL Certificate for Parts of an Application
By Rick Masters
http://devcentral.f5.com/Default.aspx?tabid=29&mid=356&ctl=ArticleView&articleId=39
when CLIENT_ACCEPTED {
set needcert 0
set gotcert 0
When a client does an SSL handshake, this rule event is triggered. This is the time to validate that a certificate has been received. If a certificate has not been received, but we were expecting one ($needcert == 1), then the connection is rejected. If the certificate has been received, we note that for future reference (set gotcert 1) and we release the current request (HTTP::release) if we were waiting for a certificate before releasing the request.
when CLIENTSSL_HANDSHAKE {
log LOCAL0.warn "cert count=[SSL::cert count] result=[SSL::verify_result]"
if { [SSL::cert count] == 0 or [SSL::verify_result] != 0 } {
log LOCAL0.warn "Bad cert!"
if { $needcert == 1 } {
reject
else {
log LOCAL0.warn "Good cert! ($needcert)"
set gotcert 1
HTTP::release
Here we process an HTTP request. If the request is for a directory that has been designated for extra security, then several things happen. We freeze the HTTP request until the client certificate is received, we tell SSL to require a certificate, we tell SSL to renegotiate now, and then we set a flag that indicates we need a certificate.
if { $gotcert == 0 and [HTTP::uri] starts_with "/needcert" } {
log LOCAL0.warn "Requiring certificate..."
HTTP::collect
SSL::cert mode require
SSL::renegotiate
set needcert 1
else {
log LOCAL0.warn "No cert needed."
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    We've recently discovered that many of the SSL::cert functions that worked in 9.1.x are broken in 9.2.x. I'm not aware of any workaround besides reverting to the maintenance branch (9.1.x).
    Please open a Support case with the specifics you encountered. They will create or link to CR for your issue, and let you know when it gets fixed.
    /deb
  • Nathan_Pearce_4's avatar
    Nathan_Pearce_4
    Historic F5 Account
    Two CR's have been created around this issue - CR58837 and CR68339.
    Please contact F5 Support for instructions on obtaining and installing the Hotfix.
    br,
    n
