cjunior's avatar
cjunior
Aug 13, 2018
Some SSLO issues and low performance
We are facing issue regarding on performance and fails to navigation when trying SSLO. We have a simple virtual environment setup, where our SSLO has only one firewall as inline service, and an datagroup to bypass few ssl traffics. We are using SSLO as ingress and egress at same box in L3, and all traffic (tcp, udp, any) are send and get back thru that inline service. Before we had error with "http_process_state_prepend" that are solved with last version "13.1.0-3.0.260.6.265".
But, we still failing to navigation on many sites and functionalities, because for some reason, requests are failing on browsers, so we can see connections reseting. On SSLO this issue are silent to the logs, so for now we don't have idea what we need to do on it.
Meanwhile, this SSLO is killing download and upload performance, so we could check this by sending traffic direct to the firewall and still using LTM as a internet gateway.
Any ideia about this issue?
