SOAP monitor return value?
I setup a SOAP monitor and it appears to be working in terms of posting and getting a reply but I can't figure out what to put in the Return Value field. Here's the body of the reply (formatted for readability):
(SOAP-ENV:Body)
(archxsd:datasvc_server__status.ddf_out)
(table_)
(row)
(OUTPUT_VAL)true(/OUTPUT_VAL)
(/row)
(/table_)
(/archxsd:datasvc_server__status.ddf_out)
(/SOAP-ENV:Body)
I've tried OUTPUT_VAL and true in the Return Value field of the SOAP monitor; still down. Type is bool. I must be missing something...
Thanks - Al
- hoolio
Hi Al,
Here's a good solution to start with for troubleshooting:
sol12531: Troubleshooting health monitors
Aaron
- blb_11599Historic F5 Account
Al --
Currently the SOAP monitor only looks at top-level objects. It can't read values nested in tables. If your organization has a support case about this issue, then it's likely a hotfix is forthcoming for you in the next couple of days (I own the escalation). If you do not, I suggest opening one and asking for a hotfix for ID427479.
There are some workarounds also. An HTTP monitor works correctly, and there are some external SOAP monitors on devcentral that also work. This will be resolved in a future release, without question.
-- Ben
- chrispa_133041
can someone provide an example SOAP response, where a boolean is returned? I can't figure out how such an response should look like as I always get:
Caught SOAP Exception: Cannot convert a struct to a string.
Thanks Chris
