liycheng_55020
Oct 21, 2009SOAP-ENV:Client Unknown method "{urn:iControl:ITCMSystem/SystemInfo}:get_product_info"
Hello
I am getting "SOAP-ENV:Client Unknown method "{urn:iControl:ITCMSystem/SystemInfo}:get_product_info""
from a BIG-IP Version 9.4.6 401.0
does this method not existe on this version?
any alternative?
- liycheng_55020
and where can I get a checklist about methods on or not on different versions? - L4L7_53191
I believe the method should be get_product_information()
Check here for the details on your methods: http://devcentral.f5.com/Wiki/default.aspx/iControl/System__SystemInfo.html.
-Matt - Matt is correct, for v9 and above there was a change in the API and it seems (from your use of the ITCM* namespaces) that you are still using the v4.x APIs. If you go into the iControl API reference
http://devcentral.f5.com/Wiki/default.aspx/iControl/APIReference.html
Click here
you can browse down into the interfaces and methods and you will see an "Introduced" attribute to each method. This will indicate the first BIG-IP version that the method was added in. So, if you look at the System.SystemInfo.get_system_information() method you'll see that it was introduced in "BIG-IP_v9.0" which means it's available in every release including and after BIG-IP v9.0.
BTW, which language are you developing your iControl application with? We have some helper libraries for Java, .Net, and Python if you are going with one of those.
Hope this helps...
-Joe - liycheng_55020
Thanks for all your help.
I am starting code a samll monitor tool using perl. - liycheng_55020
and I am sorry to update you guys again:
SOAP-ENV:Client Unknown method "{urn:iControl:ITCMSystem/SystemInfo}:get_product_information" - Change the "ITCMSystem" to "System". ITCM was for 4.x.
-Joe
