cedrick_115365's avatar
cedrick_115365
Aug 19, 2014
SNMP without management interface
Hi all
I have the problem especified in the SOL7530(https://support.f5.com/kb/en-us/solutions/public/7000/500/sol7530.html)
the management port IP address is typically associated with the system's host name. However, in some cases the management port is not used, or remote SNMP systems reside on an IP network reachable through an interface other than the management port.
I have made the workaround procedure of SOL7530, but it don´t work.
Can anyone help me???
  • I need to configure the specific OID on the bigip SNMP configuration or can to leave default? (.1)
    .1 (default) allows all the oid tree.
    • Fernando_Tician's avatar
      Fernando_Tician
      Hi guys, I have the same problem, i tried the SOL7530(https://support.f5.com/kb/en-us/solutions/public/7000/500/sol7530.html without sucess. Someone got the solution for this issue? Thanks
