SNMP Monitor DCA Simple True/Green Red/false
I want to create a SNMP monitor that is basically just a true/false on the monitor check.
Following the article at
https://support.f5.com/csp/article/K14114
I created a SNMP DCA base
· i3IcGenSwitchoverRole = 1.3.6.1.4.1.2793.2.1.5.0
· i3IcGenSwitchoverRole_threshold =2
· i3IcGenSwitchoverRole_coefficient = 1
The threshold is based on the chart below:
Type Access Description
Integer read-only This object displays the switchover role for this CIC server:
1 = NotApplicable because the Server is not in a Primary/Backup configuration.
2 = Primary
3 = Backup
4 = Failed
What I really want is for server to be green only if the i3IcGenSwitchoverRole is 2. I don’t want a calculated value. A calculated is wrong because the “Backup” is a higher number and is considered by the F5 to be the preferred. If I can do an SNMP true/false on a single value then the application can control its own primary / backup configuration. Otherwise enabling and disabling of the servers has to be done manually.
- David_Howard
I imported a script and did an external monitor check. I created an external monitor (https://devcentral.f5.com/s/articles/ltm-external-monitors-the-basics) with the variable PREFERRED_STATE=1 and a script. Here is the script:
#!/bin/sh
# remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)
# OID i3IcGenSwitchoverRole = 1.3.6.1.4.1.2793.2.1.5.0
# Preferred States Numbers
#1 = NotApplicable because the Server is not in a Primary/Backup configuration.
#2 = Primary
#3 = Backup
#4 = Failed
OID="1.3.6.1.4.1.2793.2.1.5.0"
NODE_IP=`echo ${1} | sed 's/::ffff://'`
NODE_PORT=${2}
PIDFILE="/var/run/`basename ${0}`.${IP}_${PORT}.pid"
# kill of the last instance of this monitor if hung and log current pid
if [ -f $PIDFILE ]
then
echo "exceeded runtime needed to kill ${IP}:${PORT}" | logger -p local0.error
kill -9 `cat $PIDFILE` > /dev/null 2>&1
fi
status=$(snmpwalk -v 2c -c Genesys $NODE_IP $OID| awk '{print $4}')
if [ $status = $PREFERRED_STATE ]; then
echo $status
fi
rm -f $PIDFILE
exit
