Subrun's avatar
Subrun
Aug 20, 2019
SNI based routing required ?
Hello,
I have 2 name need to be resolved with 1 IP Address . For example hostname TEST.COMPANY.COM and TEST1.COMPANY.COM need to be resolved with 1 IP . And both has individual certificate. I was thinking to resolve multiple SSL Hostname on 1 IP I need SNI based routing configuration. But before configuring SNI based routing I do see that I can open default webpage with both name. Just note that both name actually has same backend server.
Before SNI configuration, I configured only 1 SSL profile with default cert.
Based on my scenario do I still need to configure SNI based routing ?
  • JG's avatar
    JG
    Can you check if the certificate covers both domain names, e.g. a wildcard certificate ("*.company.com") or with SAN?
  • Subrun's avatar
    Subrun
    Both certs will be generated individually , there is no wildcard cert or SAN planned to be configured for these 2 certs.
    Just note that at this moment , only ONE self signed cert configured.. Public CA generated cert will be installed for both names and called at the Virtual Server Configuration. So my point is when I will configure 2 SSL Profile on a single VIP do I need to SNI settings or not ?
  • JG's avatar
    JG
    You don't need SNI and multiple SSL profiles if you get a SAN certificate, or a wildcard certificate in this situation.
    • Subrun's avatar
      Subrun
      Thank You.. Probably I am making the plan complex while thinking about SNI. But If I come up with individual SSL Cert then I need to do SNI right ?
