swiss2000_13853
Nov 23, 2009SNAT pool and persistence
Hi all!
I have a LTM-setup (10.0.1) with a SNAT Pool containing 5 ip addresses. So each connection uses the next SNAT address (round robin).
But for persistent connections (source persistence), i'd like the LTM to use always the same SNAT address, and not to change it during the session. Otherwise some of my applications have problems with session management...
Is there a way to configure the SNAT pool in a way that persistent connection always keep their SNAT address?
Thanking you in anticipation, regards
Marc
- hoolio
Hi Marc,
Here is a related post:
http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=86374&ptarget=86389
Aaron - hoolio
Hi Mark,
Do you think mapping the source IP address to a SNAT IP would work for you (assign 1/x IP addresses to one SNAT IP)? If so, I can put together an example. Else, the UIE session persistence method would take a bit longer to give an example for.
Aaron - hoolio
Something like this maybe...when CLIENT_ACCEPTED { Create some snat name to IP variables set snat0_ip 1.1.1.1 set snat1_ip 2.2.2.2 set snat2_ip 3.3.3.3 set snat3_ip 4.4.4.4 set snat4_ip 5.5.5.5 Test with a dummy client IP address set client_ip "10.11.12.13" log local0. "\$client_ip: $client_ip" Scan the dummy IP address for each octet scan $client_ip {%[0-9].%[0-9].%[0-9].%[0-9]} a b c d log local0. "result: \[expr {$c % 5}\]: [expr {$c % 5}]" Use modulus 5 on the third octet log local0. "Snat command: snat [set "snat[expr {$c % 5}]_ip"]" Apply the SNAT IP to this connection snat [set "snat[expr {$c % 5}]_ip"] }
Once you're done testing, you can replace the $client_ip variable with [IP::client_addr]. You could also experiment with using a datagroup to store the SNAT addresses or maybe an array.
Aaron - hoolio
Actually, it looks like getfield is a lot more efficient for this compared with scan. So you could replace the scan command with getfield:when CLIENT_ACCEPTED { Use a local array to configure the 5 SNAT addresses set snat_ips(0) 1.1.1.1 set snat_ips(1) 2.2.2.2 set snat_ips(2) 3.3.3.3 set snat_ips(3) 4.4.4.4 set snat_ips(4) 5.5.5.5 Use getfield to parse the third octet from the client IP address Get the modulus of the third octet against the number of the SNAT IPs in the array set snat_number [expr {[getfield [IP::client_addr] "." 3] % [array size snat_ips]}] log local0. "Client IP: [IP::client_addr], SNAT number $snat_number, SNAT IP: $snat_ips($snat_number)" Apply the SNAT snat $snat_ips($snat_number) }
Aaron - swiss2000_13853
Hi Aaron
Thank you very much for this proposal!
I currently use a general SNAT for all origin adresses to my SNAT pool.
So now, i have to disable this SNAT and add the iRule to all my VS?
Regards
Marc - hoolio
Hi Marc,
You could use this specific SNAT rule on any VIP where you want to "persist" clients with the same SNAT IP over multiple connections. The more general default SNAT would take lower precedence than SNAT called from an iRule. So you could leave the default SNAT enabled for any other VIP which you don't need to use the same SNAT pool IP for each client.
Aaron - hoolio
dupe... - hoolio
I figured out that using a hash on the full client IP should give a better distribution across the SNAT addresses compared with using getfield to parse a single octet. The CPU usage is virtually the same as getfield. The rule is here:
http://devcentral.f5.com/wiki/default.aspx/iRules/snat_pool_persistence
Aaron - Joel_Moses
Just FYI, this iRule does pretty much the same thing; give you two options to get there.
http://devcentral.f5.com/wiki/default.aspx/iRules/Exchange2010_SNATPool_Persist.html - hoolio
I thought crc32 might give better distribution but be lighter weight than the binary and format commands. But I haven't compared to see which is more efficient. Anyhow, more options are better than less :)
Aaron
