Snat issue
Hi, I have faced an issue in my infrastructure, we have 4 servers running in a pool. i used virtual server ip as snat and it was having an issue, all the hits were served only to 2 servers in the pool, once i moved the snat to automap i began to see the hits are equally shared to all 4 servers. Not sure what was the cause. Note: Roundrobin method i am using.
Hi Dinesh,
This issue can be due to routing issue. Cause of the issue can be that 2 pool members are reachable using SNAT IP while there is no routing of the other pool members from SNAT IP. Share the pool member IP address and output of the following command: route -nThanks Syed
- Dinesh3888
Hi Syed, Thanks for your reply. here are the ouput details, [root@austltm1:Active:In Sync] config route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 10.41.253.8 0.0.0.0 255.255.255.252 U 0 0 0 HA_Vlan_Cross 152.135.149.128 0.0.0.0 255.255.255.128 U 0 0 0 mgmt 152.135.149.128 0.0.0.0 255.255.255.128 U 9 0 0 mgmt 127.1.1.0 0.0.0.0 255.255.255.0 U 0 0 0 tmm0 127.3.0.0 0.0.0.0 255.255.255.0 U 0 0 0 mgmt_bp 152.135.134.0 0.0.0.0 255.255.255.0 U 0 0 0 External_Aust~1 192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 HA_Vlan 127.2.0.0 0.0.0.0 255.255.255.0 U 0 0 0 mgmt.1 127.7.0.0 127.1.1.254 255.255.0.0 UG 0 0 0 tmm0 0.0.0.0 152.135.134.1 0.0.0.0 UG 0 0 0 External_Aust~1 0.0.0.0 152.135.149.254 0.0.0.0 UG 9 0 0 mgmt [root@austltm1:Active:In Sync] config Pool Member: 152.135.116.61,152.135.116.62 , 152.135.124.26,152.135.247.96. Weird Thing is i have ports 443 and 80 running on same pool. in 443 pool i have hits on different 2 servers and for port 80 i get on different 2 servers. in that case the servers could be reachable from Snat ip?
- nitass
Employee
i think so.
have you checked port 80 and port 443 configurations on the servers? they might have something filtering source ip.
