ashu2280's avatar
ashu2280
Jul 23, 2026
R5600 LAG question
Is is recommended to add ports into LAG from different pipelines? If we configure a LAG with port 3 from pipeline 1 and port 7 from pipeline 2. What will happen if port 3 from pipeline 1 goes down? Would it impact the traffic?
I am trying to understand pros and cons of adding ports into LAG from same pipeline and different pipelines. I could not find a clear F5 reference document or SK article.
  • Hi ashu2280​ ,
    it is definitely recommended to put ports from 2 different pipelines in a LAG, not 2 from the same pipeline.
    What will happen to your traffic if a link goes down? Short answer: traffic keeps flowing, just over fewer links.
    You might see a short burst of packet loss or reordering during the transition. TCP will typically recover on its own (retransmit/reorder), but it's not instant or lossless.
    Aggregate bandwidth drops proportionally. A 2-member LAG losing one interface goes from 2x to 1x link capacity — so if you were pushing close to full utilization across both, you'll see congestion.
    Take a look here: rSeries Networking - Link Aggregation Groups
    Cheers
    Daniel
