SIP load balance criteria by call no. using irule
Hi all, I got a requirement to load balancing SIP by call number.
for example, when client phone No. 0811234567 calls to No *123 in SIP header [SIP.To] shows *1230811234567 and client phone No. 0817654321 calls to No *456 in SIP header [SIP.To] shows *4560817654321
There is two IVR servers in pools for this Virtual server. Once VS get the request, first call must route to IVR server-1 and second call must route to IVR server-2
If the client calls to no. *123 Virtual Server must point to IVR server-1 and calls to no *456 must point to IVR Server-2
Anyone who familiar with SIP, please suggests
Thank you
- Kevin_Davies_40
Nacreous
Set load balance to round robin. Set persistence to blank Universal with the following iRule
when SIP_REQUEST { persist [string range [SIP::to] 1 3] }This will persist on the first three numeric characters of the destination number to the backend server. If however you want exactly as you specified above then..
when SIP_REQUEST { switch [string range [SIP::to] 1 3] { 123 { node server1 port1 } 456 { node server2 port2 } } }
