Gopal123's avatar
Gopal123
Sep 02, 2024
Shut down and configuration reset of BIG IQ device
Hello Everyone,
Kindly if you can help me with the command/GUI step to shutdown and reset the existing configuration that will be helpful. The BIG IQ version is 7.1.0
Thanks in advance.
  • Additionally, the intension is to reset current configuration to null and shutdown the BIG IQ box remotely.
    • Paulius's avatar
      Paulius
      Icon for MVP rankMVP
      I don't believe this would be achievable remotely because you most likely have multiple partitions but you can try the following.
      https://my.f5.com/manage/s/article/K15886
  • Hi Paulius,
    Thanks for the document it is helpful. Can you please provide me some documentation to shut down the BIGIQ device remotely that will be a great help.
    • Paulius's avatar
      Paulius
      If you SSH to it you can go into bash and run the "halt" command.
      • Gopal123's avatar
        Gopal123
        Kindly if you can help me with the full command. Is it "shutdown -H now"?
