vin_dev_221203's avatar
vin_dev_221203
Feb 16, 2017
Sharing same VLAN between vCMP guest
Hello,
This question is regarding to sharing same VLAN between vCMP guest for F5 viprion platform.
lets say, I have a VLAN 10 which is tagged to interface 1.1 at vCMP host level and propagated to Guest A in common partition.
-For the guest B can I use same VLAN?
-What would be the recommend way to share VLANs between guests?
-Can we tag VLAN 10 to 1.2 interface at vCMP host level and share it with Guest B?
  • Yes, the VLAN can be shared between several guests. Be careful though not to use the same MAC (masquerading) or IP (including SNAT IPs) on your guests unless they form a device-group with floating IPs.
    • MartinRenshaw's avatar
      MartinRenshaw
      Sorry to add this to an old thread, if using a vLAN between two guests does the traffic remain on the chassis or does it need an external switch/bridge to connect the guests?
