shawn306_84070
Jul 30, 2010Sharepoint load balance stats question
We are load balancing two wfe's for sharepoint. It looks like the bits and packets are balacing ok but the connections seem way off.
One WFE in the pool is currently showing 90 active connections. The other one is showing 10.
the max on one is 245 and the other 45.
So how is it possible that the bits and packets are balancing nicely but the connections are way off ?
We are using round robin with persistence.
Shawn
- Chris_Miller
Altostratus
Are you using OneConnect or SNATs? Is the F5 seeing the true-client IP or is it being proxied on the way?
