F5_Jeff's avatar
F5_Jeff
Icon for Cirrus rankCirrus
Jul 11, 2017
SFTP using Non-authentication Method
Hi everyone.
May I ask some information about configuring a SFTP in F5 LTM?
from the tcpdump, when performing testing the connection, we can see that we are receiving successful return.
We also performed using FTP only. This one is successful and did not encounter any issue. This means that we are configuring the F5 correctly.
What could be the cause of the error when using SFTP? is this related to the SSH key? what if we are going to implement a non-interactive authentication?
Thank you for your responses!
  • Hello
    Could you share errors/logs or a capture that you are getting when using SFTP.
    Also, are you load balancing SFTP servers ? or you want to connect to the BIG-IP using SFTP ?
    Please clarify
